Touch screen erratic behavior 2018
Becrotteau
Pennsylvania us
V8
Our touchscreen has started to have a mind of its own . Not sure why ? Can anyone help
with this ?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
it does seem to be delaminating. What are the options ?
If it's not bad you can try keeping it cooler to stop the ghost touching. Otherwise screen replacement for $80-$250. It's not difficult to replace the screen and I'm happy to walk you through it .
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Can you point us in a direction to get a new screen ? Clueless on what to look for .
Their are three revisions
SL01
SL02
SL03
The part number revised to correct delamination is LA084X01 SL03. Those cost the most. If you search for that number you will get all part numbers. Anything under $200 is likely not an SL03. There are also many counterfeit screens now that likely work but are not made by LG.
If you find one you think you want to buy, feel free to post the link here and I'll check the listing to tell you what it is
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Having been at that ghost touch point, just toss the digitizer in the trash. It’s overheated long enough that your fingers have been imprinted into it.
Ah! Is that how that works? The most commonly touched areas are what triggers at failure? Makes sense...
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
That looks like a good genuine LG part (the knock offs have weird conterfeity white labels on the back that are meant to look like the LG label but aren't). If I were looking for an SL03, I would buy what you found.
nlambert182
Huntsville, AL
So just take it off and rock on? :)
Replacing the screen is the only "easy" fix. It will come with the digitizer. It isn't worth trying to just replace that piece. Removing all the glue is a lesson in futility.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Agreed, I've done it myself and getting it to look right after curing is a job for the factory.
