Touchscreen Stopped Working
Scot Harlow
Centerton, AR
The console touchscreen stopped working in my 2019 RAM 1500. Is there a reset I can perform? Diagnostic?
300MAG
Disconnect battery for a few minutes then reconnect. Don't be alarmed if things are missing from radio when it reboots after you reconnect the battery. It's common for things like sirius, heated seat controls and cameras not show up right away. They usually show up 1-2 hours later.
Sent from my GM1917 using Tapatalk
RamCares
n/a
n/a
Hi Scott,
Sorry to hear about the concerns you were having with your touchscreen. For future reference, in order to complete a soft reset of your Uconnect system, please perform the following steps-
1) Put your vehicle into the accessories mode (ACC or RUN)
For keyless start (push-button) vehicles: push the start button twice without having your foot on the gas or brake pedal
2) Hold down the Phone and voice recognition buttons (or tuner and volume knob), at the same time, for thirty seconds.
3) Let go of the buttons
4) Turn the vehicle off
5) Open driver’s side door for thirty seconds (or until dash illumination goes black)
6) Close door
Feel free to send our team a private message if you'd ever like additional assistance.
Thanks,
Courtney
Ram Cares
sddingman
Magnolia, AR.
Hi Scott,
6) Close door
Thanks,
Courtney
Ram Cares
I have the same issue with my 2020 Ram, have already tried disconnecting the battery (no luck) and the soft reset listed her (no luck).
Dealership was no help.
sddingman
Magnolia, AR.
OrlandoTragic
Orlando, FL
Having the same issue on my 22 Ram 1500 as of today. This uConnect system is garbage.
hiroshi
Japan
5.7L V8 Gas
I have same issue on my 2020 Ram 1500 with 8.4" screen.
Someone can tell how to fix the problem ?
Etchin
Has anyone had any luck fixing this issue? I've tried a soft and a hard reset and still can't get my touchscreen to work. It's so frustrating that nobody at RAM or the dealership knows the solution other than buying a new unit, which means I'm likely to have the same issue at some point.
FL-RAM
PENSACOLA, FL
2022 Bighorn Night Edition
V8
Mine does that every once in a while. Press and hold the power button for about 10 seconds and it should reset the system. That always fixes it for me.
