Toughest bed liner?
Armyman14
4.7 V8
What is the toughest, roughest bed liner? I want to use it on my step bars but I want it to have a crazy amount of traction all the way over it.
Davy120
fairchild afb
Herculiner is pretty rough and super grippy
Sent from my MAN CAVE using Tapatalk 2
Armyman14
Armyman14
4.7 V8
Where do they sell the spray Herculiner?
Davy120
fairchild afb
Idk if herculiner is in spray form, but i got my roll on kit from napa. But you can find it at almost any parts store or i think even walmart.
Armyman14
Armyman14
4.7 V8
Ahh well I'm needing a spray on. It would be way too hard to try to roll that stuff on to a cylinder
TexasRammer
College Station, TX
Herculiner is also spray on, they dont make different kinds for spray/ roll on. I got mine for like $78 shipped on ebay which is like $10 than any store
Redneck Ryan
Tampa Fl
2005 4x4
I'd just have someone Line-x it...get it professionally done and you won't have to worry.
Ant-man
OR
5.9 Magnum
My truck has had rhino lining for goodness... 10 years? And no damage, peeling, sratches or anything at all. Although the decal broke so now it just says 'no lining', hah.
Another note is we've been through 110+ temps, down below freezing. She's always been used for lumber, sports equipment, ect.
badblackram06
MS
Yep line-x or anything similar will be your best bet. I spray a line-x type liner where I work. You can control how thick it is and how much texture/roughness you want. I have my bed and my little toolbox sprayed with it.
99RamSport360
5.9L Magnum 360
I herculined my bed, and hate it, it came out as a gloss black like it was supposed to, but faded a week after I had it, and it is easy to accidentally scrape it off... Just my opinion
Davy120
fairchild afb
You gotta add the uv protectant to the herculiner just like with any other bed liner
Poriggity
Cummins 5.9
Any "do it yourself" bedliner will peel off if not properly installed. You have to REALLY prep the surface well first. Lots and lots of sanding and cleaning of the surface first..
Scott
Davy120
fairchild afb
Yea i worked at a shop that did linex, so i learned how to prep from them
Armyman14
Armyman14
4.7 V8
So what are the proper procedures because I apparently messed up lol
badblackram06
MS
Of course tape and paper off the area to your liking. I like to clean the area before sanding just to be sure i don't sand any oil, grease, etc into the scratches. I try to use at least 80 grit, but I like to use 40 grit. Next is to clean clean & clean some more. Any sanding dust or possible oil will contaminate the bond and will cause it to pull up. I use lacquer thinner to clean. The final step is to make sure it's all dried out and no residue is left. Now your ready to apply the liner.
Armyman14
Armyman14
4.7 V8
Alright thanks, on one of the dupli color paint things it said to use dupli color prep spray. It's called Duplicolor grease and wax remover. Is this good enough? Would a self etching primer get it to stick to the chrome bars that I will sand down with 60 grit
badblackram06
MS
The grease and wax remover is much like brake cleaner but it will work great.
Both sanding the chrome till its rough or using the self etching primer works.
Davy120
fairchild afb
Use 80 grit then clean with acetone thats what my shop used. The self etching works good too i used that and then sprayed bed armour on to my toolbox and its holding the cold so far
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Rhino and Line X are both great. Rhino is not as easy to apply and is put on thicker so it is often not as appealing as Line X but very functional.
Armyman14
Armyman14
4.7 V8
Well I was gonna sand down with the 60 then clean then use the primer. I tried bedlining it a while back, I sanded it down with the 80 grit and cleaned off then used bed liner and it won't stick, comes right off with my fingernail. So I'm gonna have to use a wire brush drill but to get the old stuff off, sand it down harder with the 60, then use the self etching primer then use bed liner. Does Bedliner have a shine to it?
Reticle918
