Towing odometer, AlfaOBD able to correct?
Earl Zeis
Saint Thomas, PA
6.7L
I'm looking at upgrading my 2018 Ram 3500 Tradesman 6.7l diesel evic to the 7" premium evic.
My concern is I track my 5th wheel miles on my evic towing odometer. I don't know if that's stored in the evic, BCM or the brake controller module.
If it's stored in the evic, can AlfaOBD rewrite it like the truck odometer and hours?
Thanks,
Earl
skuppy069
canada alberta
2018 1500 cc
Thanks,
Earl
I will connect to my trailer brake module and see if the hours are in there .
skuppy069
canada alberta
2018 1500 cc
So I connected the trailer module and I don’t see any kilometers in there .
I also connected to the ecm and didn’t see any kilometers with regards to trailer KM etc .
Same as in the IPC
I haven’t connected to the tcm yet .
Maybe something in there .
I will look at the tcm this evening and let you know .
I have feeling that the towing Miles are accumulated in the ipc itself
But will update once I finished looking at the tcm
Earl Zeis
Earl Zeis
Saint Thomas, PA
6.7L
Thanks for checking! My gut tells me it's all done in the evic. If so, if alpha can write the truck odometer and hours, just maybe it can do the towing.
Thanks,
Earl
rixter99
SW Arkansas
2014 3500 SRW
Cummins i6.7
Thanks,
Earl
I just did the 7" update myself...On the 'Trailer' screen of it, the 1st option shows "Distance mi" with the option to "Hold > to Reset."
Earl Zeis
Earl Zeis
Saint Thomas, PA
6.7L
Yep, same as the 3.5". I want to keep my current towing odometer, not reset or loose it when going to the 7". Thought it looks like that's what's going to happen. I haven't found that anyone has been able to write the towing odometer.
Earl
rixter99
SW Arkansas
2014 3500 SRW
Cummins i6.7
Earl
I got ya'...Send in a request to the AlfaOBD developer and see if he can add it into an update or give some insight/direction - [email protected] I believe is the address...
