Towing without safety chains.
clh1220
st Louis
I never forget to use them. They work when needed, I found that out coming up the boat ramp one day. I had my lower receiver in and the wife hit a bump which hit the dolly wheel on the trailer and knocked it off the hitch. Chains worked I had to block the boat tires and crank it up and put it back on. Too top it off my sliding window wouldn't close.
Searay245se
BrookPark Ohio
2015 Power Wagon Laramie
And that is why it is illegal to not have safety tow chains on.
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
I was towing a tandem axle car trailer with my lifted homespun 3/4 ton Ramcharger on 36" Swampers.
Hit a bump. The trailer with the 2 5/16" ball (I was told 2") came off my 2" (luckily after my 6 hour road trip to return with an 80 W250 4x4 in tow) ball as I was returning the trailer. Lucky it was empty. It caught on the chains and the chains did stop the trailer from hitting the ground.
BUT they did cause the trailer to swing under my truck and take out my gas tank.
There I was, on the road with a big hole in my gas tank as my gas poured out everywhere.
Had enough left in the tank to get home.
Rotzilla
colorado
6.7 CTD
I was going fishing with a buddy and his kids, the kids were in charge of hooking up the boat. We made it approximately 3 blocks when there was a loud bang and the truck began bucking.
The kids had set the coupler on top of the ball without opening the coupler, thank goodness they hooked the safety chains on.
Now my buddy on the other hand got the ******** award for not checking the work of 2 eleven year olds.
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
My wife got hit in her mini-van when a construction welder's utility trailer came loose without safety chains and slammed into her drivers door side. Dealt with neck issues for 10+ years that eventually lead to two vertebrae in her neck having to be fused.
Jerry1984
Meridian, Idaho
They sure were in a hurry to see if they needed help, not. They were very calm for just hearing what had to be a loud collision.
PippinAin'tEasy
Same damn thing when I was a kid and forgot the tongue pin on a dump trailer coupler. Punched a nice, neat hole right in the tank. The old man still won't let me live it down.
Sent from OK, I swear this is my last beer using Tapatalk
CF_Smith
Canada
HEMI 5.7
I was towing canoe trailers for a summer job once. Nothing too heavy, but with 10-12 canoes on each trailer. I had a co-driver with me who never towed before. I towed out the first couple, taught him how to hook it all up - proper use of chains, coupler, wiring etc. On the third trailer, I got a few Km's out, hit a bump and the trailer was bouncing around. Luckily the chains caught the trailer and there was little damage. The only damage was that half of the plastic crank handle was ground off. Luckily, the tongue of the trailer slid under the truck and made contact with the hitch, so the truck was uninjured.
So what happened? There was 7 of these trailer and they were identical, same make/model/size. However, ONE of them had a larger coupler then the rest. It just so happened that it was the one he hooked up. He did everything correctly except lift the tongue to make sure its connected securely (these trailers are light enough to do so). The blame was really mine, however, as I did not check the connection beyond a visual check (I also didn't lift the tongue).
Like I said, luckily no one/equipment was injured. I definitely learned my lesson and check the coupler size now. The scary part is how far I was able to go before there was an issue, those chains definitely saved the day. I always used the chains and thought of it as a redundancy until then. I wouldn't even consider to tow a trailer (on road) without them now.
For those of you who haven't experienced it, its bouncy and shakey, but the trailer was otherwise stable (not swaying). It felt more like trailer brakes coming on and off. I very slowly came to a stop, making sure the truck was pulling the trailer as much a possible, to avoid truck/trailer collision. However, the tongue still did hit the hitch and had it've been offset left/right there would have been damage to the bumper, tailgate and canoes (possible something could have gotten snagged underneath, too, I guess).
^^Moral of these words: use your damned chains, and use them properly.
crazy_luck
Minnesota
My friends dad borrowed an F-350 and a flatbed trailer a few years back to pick up his '55 Chevy truck from a field in Montana. While he was heading West thru South Dakota, he blew a tire on the (empty) trailer at about 70mph. The trailer detached and flipped, but was still chained to the bumper. The nice round holes the chains were attached to turned into elongated oval shaped holes, and the bumper had a pair of bumps sticking out where the metal deformed...
He was able to get the trailer recovered, tire fixed and continue on to Montana to get his '55 and return with no other incidents, but he said something to the effect of wishing he'd packed more than one pair of clean underwear in his overnight bag... lol
Quint
Minnesota
2021 Big Horn 1500
5.7L v8 eTorque
They may have only heard something and were still trying to understand/process what was going on. I won't fault those guys without knowing all of the facts. They may have started running immediately after the video cut out. The victim might have already been standing outside of his truck surveying damage so they knew he was okay. To many unknowns to get worked up.
It's a good idea to do a final safety check before leaving. After everything is ready I do one final tour around the trailer to make sure that everything is tied down, tight, and secure. Never rush through safety checks and NEVER trust anyone else when loading up your truck. It's your duty to verify everyone else's handy work.
mtofell
Yep, after watching that a couple times I'm thinking it's a coin toss whether or not it's real or doctored. The guys don't seem to be walking with any purpose considering what just happened? And most of all the passing traffic doesn't even slow down afterwards.... they just keep streaming by at normal speed. No one even slows down? Isn't there debris in the road? Hmmmmmm.
2011 Ram 1500
Im glad Im not the only one with a story like this...
I went on a fishing trip with my brother and his future father, in law the day before his wedding. My brother attached the father inlaw's 21 ft pontoon to his truck and we were off.. We were driving down the road and heard something metal fall onto the road, but we payed it off as nothing since we were already running late. Well the next bump later the trailer falls off... Apparently the safe pin on the receiver hitch never got pushed all the way in. I don't recall any damage done, except for the fact that his really pissed off his future father inlaw.
So yeah those two little chains are life savers
Csanders1992
Always cross your chains as well
