Traction Control Question
Brian Carroll
Chickamauga, GA
Just curious...if traction control is not working properly, should I have a warning light on the dash? My 2017 Crew-cab wants to get out from under me while negotiating turns and it has no problem spinning the back tires from a stop. My little boy actually asked me if I “drifted” the other day when it happened. I thought traction control was supposed to prevent that. I’ve checked the button in the cab every time I lose traction and it indicates that TC is engaged. Other than the fact that i still have the crappy GY Wranglers from the factory, is there something else going on?
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
I recall back in my 1500 the truck would also lose traction very easily in the back on the factory Goodyears. Also with TC engaged to normal mode. Once I put A/T tires on it there was no more spinning unless I pretty much floored it. Could be the sucky tires. I hated those.
MADDOG
Living in a Firepit
Traction control won't keep it from spinning. Rather, it mitigates the spin once the wheels break loose.
I suspect it's those Wrangler tires. They have a high durometer measure (harder rubber) and just aren't that great for dry traction, IMHO. The Transforce on my CTD were pretty bad too.
Once you upgrade the tires to something a bit more aggressive tread pattern and lower durometer measure you'll have to work harder to spin 'em.
Brian Carroll
Brian Carroll
Chickamauga, GA
I appreciate it the input. These tires have only got 13,000 miles on them, so I wanted to rule out any other issues before I start tire shopping.
b-rock
US
I believe I have noticed on a few rare instances that my tires have broke traction that the traction control light will illuminate on the gauge cluster while it is doing its thing - whatever that is on a conventional differential...
2017 RAM 1500 CC, LoneStar, Black Pearl
John Jensen
San Diego County
Ecodiesel
I had the same experience with the Goodyears. Replaced them at 1000 miles and never experienced it again, unless I tromp it turning a corner.
IMHO it's not a failing traction control
Brian Carroll
Brian Carroll
Chickamauga, GA
That’s why I was wondering about the TC...the light on the dash never comes on while/if it is engaged.
