nwsewell
Let me preface by saying: on wet roads, gravel, sand or any similar condition, i have no issues breaking the rear tires free with traction control off, and it does not give me any hassle.
But I recently tried doing a burnout and a couple donuts on dry concrete to check those off of my bucket list since I've never actually done either before, and my truck was NOT having it.
'19 Classic. 5.7. 8,000 miles. Vararam. Pedal Commander set on Sport. 2wd. 3.21s. LSD.
I turned traction control off, held the brakes, and eased onto the skinny pedal. The back tires were trying to break free, but it sounded like they were skipping or hopping; and the traction control light in the cluster started flashing at me.
Dissatisfied with how that worked out, i tried whipping a couple donuts, and had a similar outcome. Turned off traction control, cut the wheel to the side, mashed the gas. Tires were chirping/hopping, traction control light started flashing again. The rear end did slip out a little bit, but not how I was expecting after seeing many others do it.
After two dissatisfying attempts, i called it quits and drove on.
Any idea why my truck might be behaving this way, or what i might be doing wrong?
Sent from my VS996 using Tapatalk
