Trailer mileage
rb10de
Central Pennsylvania
I know that some vehicles are equipped with a trip log for the trailer. What I haven't been able to figure out is what package needs to be added to get it.
The manual just says there will be a Trailer Tow option in the instrument panel if equipped. Going through the build options doesn't spell it out. I must have power folding mirrors so the Trailer Tow Group is out. If I add the brake controller does that do it or is there something else?
Probably just like the Gen4 trucks, the trailer mileage is tracked by which "trailer" settings(there is four different ones) is selected with the factory brake controller. The brake controller is a stand alone option on the Gen5 trucks if you don't want the larger tow mirrors.
runamuck
Air Force
dfw
6.7 dsl
there is a selection for a towing info screen. I use that one when towing or the one that shows all the vehicle info if I want to monitor trans and coolant temps on a hot day.
R
rb10de
I know that there is a towing info screen if equipped. I am trying to figure out if getting the brake controller is enough to add that screen.
farmallboy
Croton
6.4 hemi
Not able to answer your question explicitly. But i have a tradesman and I have the brake controller. I DO have the screen for trailer info. I'm about to break 500 miles so I'll be checking it out soon.
R
rb10de
Thank you. Just to be clear - you have the controller but not the Trailer Tow Group with the manual fold mirrors?
olyelr
Kewadin MI
What I have noticed with my ‘16 is the only time it calculates trailer tow miles is when I am towing a trailer with brakes. Small trailers with just a light plug do not seem to get calculated.
The truck uses when trailer brakes are connected to log mileage on the selected trailer settings. It's also why you'll get a trailer disconnected if you unplug while the truck is running.
dexter
Banned
I use google maps and a spread sheet.
olyelr
Kewadin MI
Yep. Had that happen before too.
But, it doesnt seem to log a trailer when its only the 4 pin plug.
clayinfla
Tampa, Fl
5.7 Hemi - no etorque
I believe it only works with the seven pin connector plugged in.
RVGuy
Alberta, Canada
It uses the brake circuit to tell if there's a trailer connected. Ford uses the running light circuit and GM uses the charge line circuit.
Have had lots of problems with Fords at work because of it so had to educate myself on what circuits they all use. They'll all only count miles off the 7 way connection though.
R
rb10de
Ok. Since my trailer has surge brakes it sounds like this isn't going to work for me.
I have an app on my phone that I can turn on when I am towing and it will keep track of the mileage. I was hoping the truck would track it just by hooking up.
RVGuy
Alberta, Canada
Do you have a brake controller in your truck? You could trick it into thinking there's brakes on the circuit if you want the truck to count the miles. Might be more trouble than it's worth though. If you hooked a 6ohm resister to the brake circuit while your other trailer is connected it would think there's trailer brakes connected.
It'd be a lot of work just to make the computer count your miles but it's doable. I'd personally just use the app.
chri5k
USA
Diesel
If you do the resistor thing make sure it is a fairly good sized resistor. At 12 volts into 6 ohms it will pull 2 amps so a resistor that can handle 25 watts or more would be in order.
It might take two 6 ohm resistors wired in parallel as the larger magnets usually have a 3-4 ohm resistance.
I would test it with two resistors then wire it up to a 7 pin plug for that trailer.
