Tranny Cooler Line Noise
Tanner Nielsen
Valley city North Dakota
i know there is a select few posts about this topic but no real fix and the threads are getting a bit old so I’m wondering if there’s a fix for low rpm tranny whine through the cooler lines. I removed the bolt and added foam which make it 90 percent gone . Now it only does it till it shifts at 15mph in my 2012 hemi. I removed bracket and foam completely and nothing changed. New filters and fluid , new tranny lines with the mopar foam kit around the rubber section of line and still no fix. I hate the noise so much if I can’t fix it I’m gonna trade it in. Any new fixes ? Removing all metal lines and making rubber lines ? I’m grasping at anything here so any help please
T
Tanner Nielsen
hoping for one last shot before I take a hit and trade this off, but does anyone have a fix for tranny line noise at low RPM? friends 13' with 6 speed does not whine.
daveray9
Are you sure at this point its not MDS? Have you turned it off?
Sent from my SM-G920V using Tapatalk
wolver1385
Houston
is the MDS related to the wine? mine has the whine that sounds like power steering (but of course its not the power steering)
daveray9
you can shut it off by putting it in manual mode.. it turns off MDS, see if the sound goes away.
