Tranny flush, yay or nay?
Nogoal9932
Hey guys,
Here's the deal. I have a used, bought from private seller, 2005 4.7 4wd with 140k on it. I'm not sure the transmission fluid has ever been changed/flushed.
I am having 0 issues with the transmission. However, I'm trying to stay on top of maintenance. Is it a bad idea to get what COULD be its first transmission fluid change at 140k? Is that playing with fire?
Thanks all.
sisupower
I would drop pan and change filter and top off couple times before just flushing it. What does fluid look like ?
HemiMax05
Pearland, Tx
2011 Dodge ram
What I did in the past for years on my 05 before I sold it with 225K miles I would drop the pan, change both filters, and replaced the amount of oil that comes out in the pan which is approximately 7 qts every 30-35K miles and of course with OEM filters and atf-4 trans oil.
sisupower
That's the best way to do it with high mileage transmissions. You slowly get the bad fluid out if there is any. There is places that won't even flush a transmission if it has dirty fluid and a lot of miles. I've seen them have a lot of problems after if they did flush with dirty high mileage.
HemiLonestar
Navy Badge Coast Guard
MD
Do not flush it with that much mileage on it unless you know for sure it has been done on a regular basis since it was new.
sisupower
Hey guys,
Thanks all.
I think you got your answer bud! We are all in the same page with it[emoji1360]
N
Nogoal9932
You guys are awesome...thanks a lot!
JAMMAN
Excellent advice in my experiences.
Cgiese80
Do not flush it man. Ask any Dodge technician and they will tell you it causes more harm than good. Drop pan, change filter and refill. That's your best bet
