Trans swap to a 02 to an 06 Diesel Truck
DWSchwefel
Looking for a little help. I have a friend with a 2006 diesel 3500, with a 6 speed manual trans. The synchros are in real bad shape.
I came across a 2002 diesel 3500 truck wrecked, with a 6 speed trans.
Is it possible to swap the 2002 into the 2006?
Thanks for the help.
DaveS
85 F350 4x4 idi
Davy120
fairchild afb
Should be able to, my buddy went from his 02 auto trans to a 3rd gen manual trans
Camo Ram
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
The only thing you might have to change is the bell housing. Other than that is may be a straight swap.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I don't think there are any changes to the block between 24v to common rails
If reverse is to the inside on the 06 it's a g56 trans made by Mercedes, the 02 is an nv5600
I personally think the g56 is a better trans unless your sled pulling
Davy120
fairchild afb
Bell housing is the same, for all 2nd and 3rd gens. I can put a 2nd gen cummins manu trans in my truck if i wantes to
Camo Ram
phorrestphire
