Trans temp guage
RareTA
Hi guys, I just picked up a trans temp guage for my 03 5.7 Ram. I need to know which cooler line is the out going line on the trans. I want to put the sensor in that line as it should be the hottest fluid to get a good reading as to the temp of the trans.
Thanks in advance!
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Smart man. I still need to do this to mine. It's just in a port right now and not getting a very accurate reading.
RareTA
RareTA
For anyone who needs to know I found out it is the top cooler line on the side of the trans.
BlackedOutHemi
DFW, Texas
2012 & 2012
What exactly did you use to tap into it? And how hard was it?
RareTA
RareTA
This is what I installed in the line. I just cut the line with a tubing cutter and installed the T fitting. It took a couple of hours to do the whole install. I mounted the gage on top of the steering column just behind the emergency flasher button.
B&M 80212 Trans Temp Gage 100-350 2 1/16 Analog | eBay
BlackedOutHemi
DFW, Texas
2012 & 2012
Okay. Thanks! I have the gauge. Just don't have it hooked up properly.
