Down the Tubes
This morning, on the way to work (very steep dirt road), I tried to put my truck into 4 High.
I pulled on the Transfer Case Shifter and it did not move.
I was doing 5 mph and the wheels were not spinning out.
I stopped the truck and tried again, the shifter did not move.
The 4x4 High light did come on, and the turning radius changed a little.
I'm pretty sure the truck is in 4 High now.
I can't get it out of 4 High.
The shifter will only move if I push so hard that my hand bangs into the dashboard.
I can force the truck into 4 Low, and Neutral, but when I put the shifter in 2 High, it stays in 4 High.
There is no movement past 2 High (toward 4 High) on the shifter.
I'm guessing that the shop did not adjust the shifter when they lifted the truck.
Has anyone else had this problem?
Is it something that can be adjusted by a semi-intelligent human, or does it need to go to the shop?
I say rev the engine to about 5500 rpm and slam it in gear. Keep pushing the gas, its called a neutral drop it will fix any problems, you may have to do it three times tops for it to self correct.
Right on! That sounds WAY easier than climbing under the truck!
