Transfer case
Playnit
Magnum 5.9
I have a 2001 ram 1500 with the 231d transfer case, my question is will a 241dhd out of a ‘99 ram both with 5.9 motor work in my ‘01
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
It should work, I don't think any sensors had to be replaced between the 98-99 and 00-01 like the trans needed. Bolt pattern is exactly the same.
regularcab2500
Buffalo
5.9 Magnum
The length of the input shaft and the amount of splines on the input shaft will very likely be different.
