This just plugs into your transfer case 4x4 module right under your passenger side dash. Straight foreward from your blower motor resistor. It's about a 6x6 inch black box with two plugs in it. I'll have detailed instructions and videos on install.So where does that plug into, the BCM?
Welllll, haha. I went to ohm wires from T case to that plug to see which wire is the one out to it. The one out is green with yellow but there's three! But as I'm typing this I remembered I put a blocking diode in so nothing could back feed this may be my ohming issue. But I was just wondering if there was a pin out of the t case plug to the bcm Plug? Should have the wires for numbered. [emoji57]Ah I didn't see this in time, I have an alldatadiy acct if you need anything in the future.
Sent from my SM-A530W using Tapatalk
Yeah I believe so, looks like it's coming from 2 sources but only going to one? Kinda odd...Perfect it is the 301. But now I found a weird hiccup. If you look at the bottom left there's two t301 both say switched battery solenoid. One is #1 pin and one is #9. That being said doesnt the dotted line mean its spliced together? Kinda drawing a blank today lol
That's definately the one! Not sure if I've shared this or not but it's a major help for finding connectors. http://connectors.dcctools.com/home.htm
I'll see if I can source it. The darn things aren't cheap from most places. Happy theres a power and ground point there though.Yep thats a good site too, once you pull the number from AllData you can find the connector there.
I cant find that actual connector in stock anywhere, though. The "full repair kit" is available on ebay and other parts dealers, but Im not sure what is in it (just wire and terminals or is it wire, terminals and the actual connector). Its not cheap, either.
