Transmision Cooler
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I am not going to be towing extreme loads but heat kills trannys so is anyone adding an additional cooler to their set up or is the consensus that the factory one is sufficient?
Dubstep Shep
Houston
2014 R/T
I haven't had any issues with mine overheating.
The eight speed likes to be a little bit hot. Even towing up and down hills I haven't seen mine get anywhere near temps that would concern me.
theviking
HD's don't use the 8 speed.
68PowerWagon
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I traced down the tranny lines & the cooler is larger than I thought it was. I thought the 5" X 14" (approx.) little one in the front was tranny cooler but its for something else. Kind of surprised of how thin the actual radiator is.
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
PowerWagon: Can You take a pic of this cooler and post it? I am going to be looking into adding one... Going to try to get the mopar cooler... would like to know what I am looking for...
Thanks SyN
I can't even find a actual Mopor cooler pic on line that is used with the ZF Trans...
BoldAdventure
Airstream, USA
I haven't towed far enough yet to get a good idea of the heat levels the 6.4 will produce with our load.
But I might consider it. A few times this year in the desert I saw some temps on the 1500 that I think resulted from the exterior temp and running the A/C.
68PowerWagon
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Thanks SyN
Sorry I don't think I can do that. They are sandwiched in the middle. Ya got the radiator, a/c condenser, tranny cooler, & I think engine oil or power steering cooler all sandwiched together making it impossible to get a pic without tearing it apart.
Anything with some substantial size is going to drop your temp. On my truck at least there is plenty of room to add something. In fact there is plenty of grill that lets in air that is not cooling anything. Surprised they have not put shudders on these HD Trucks too.
If I towed a lot like "boldadventure" I probably would add another one. Doesn't hurt to have more cooling unless you get a speck of dirt or something in the line when installing it. The smallest piece of dirt will completely screw up an automatic.
warwagon98xj
2014 2500 CCSB
I tow a 10k tt with my 5.7 and on a 90 deg day towing up a 6% grade at 70 mine climbed from its normal 167 to 175 at the top of the grade, thats with a factory cooler
Sent from my 2PQ93 using Tapatalk
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Does your 2500 run the 6sp or 8sp?
warwagon98xj
2014 2500 CCSB
The 66RFE
warwagon98xj
2014 2500 CCSB
6 speed thats in tow haul mode with 5th gear and above locked out
