Transmission/Alfaobd Help
Seth Zubay
Alaska
3.0L Ecodiesel
Short review: last night I installed my push-button start kit that I received from AutoTech. I was changing settings in alfaobd to correctly have the bcm register that it is push-button now. Somewhere in between doing that and cooking dinner, my buddy thought it would be cool to change settings and now doesn't remember what he changed. Well this morning I couldn't start my truck without getting a vehicle not in park message on the EVIC. I was able to change the ignition unlock, start, run alfaobd setting to unlock the transmission and allow me to start the vehicle.
Issue Now: When turning the electronic shifting knob, it does not select a gear and does not go into gear. Also, getting a lost communication with Transmission Control Module code through alfaobd. Anyone know what settings I need to change to get this working again or if I SOL and need a reflash through the dealership?
All help is appreciated
2015 Ram 1500
Outdoorsman
3.6 V6
4x4
S
Seth Zubay
Alaska
3.0L Ecodiesel
Update:
After comparing an old alfaobd list I had on hand of all my set settings, and comparing it to the current ones, I found the issue. My shifter selection option had the wrong rotary switch option. This thread can be deleted.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Update:
Better yet post the setting you changed and it can help someone else with questionable friends too...
S
Seth Zubay
Alaska
3.0L Ecodiesel
The exact option that was change as I thought was shifter selection, was actually "VehConfig 1-Shifter Type." Where in my case it had " 4 pos Electronic Range Select with Enable Switch (ERS4ESW)" which mine doesn't have and needed to be changed back to " 4 pos Rotary Eshifter PRND DS (RS4)" to work. The selection could be difference for each person, but this seems to be standard in most 4th gen rams.
Austinv
