Transmission Clunk
docdave78
My dad's 2021 Ram Classic, V6 Warlock has started clunking when he places it in reverse. This mostly occurs when the truck is cold. After shifting a few times it goes away, or after it has been warmed up.
He also notices there are uneven shifts between 1st an 2nd gears as well when the transmission is cold. Again, after it warms, there is no noise or sensation.
Looking for other experiences that have been resolved.
I would suspect something in the drive line like u-joint, driveshaft spline, or differential causing the clunk more than the transmission. It probable with the engine rpm being higher when cold the clunk is more noticeable.
How many mile on the truck and when was the transmission fluid changed?
The 8HP transmissions in these trucks are mostly trouble free.
KalboKalbs
Supporting Member Navy Badge
Texarkana, TX
21 Longhorn Limited
Not a gear head. Perhaps apples and oranges.
2022 Jeep Grand Cherokee L. 64,000 miles. Started clunking when placing in Drive. Reverse at times. Uneven shifts.
Dealer says transmission has to be replaced. Overheated transmission. Should get my Jeep back Monday or Tuesday. MOPAR extended warranty covering. $100 deductable.
FWIW.
Grok says
How many speed transmission in 2022 Jeep Grand Cherokee L
8-speed automatic transmission.
The 2022 Jeep Grand Cherokee L (three-row version) uses an 8-speed automatic (typically the 850RE or similar TorqueFlite variant) paired with both available engines:
  • Standard 3.6L V6 (Pentastar, ~290-293 hp)
This is consistent across trims and drivetrains (RWD or 4WD/Quadra-Trac/Quadra-Drive systems). No other transmission options were available for this model year.
The 2021 RAM 1500 Classic (including the Warlock trim) with the 3.6L Pentastar V6 engine comes standard with an 8-speed automatic (specifically the 850RE transmission).
Key Details:
  • Standard pairing: 3.6L V6 (305 hp, 269 lb-ft) + 8-speed automatic (850RE).
  • This applies to both 4x2 and 4x4 configuration. Optional 5.7L V8 Hemi (~357 hp)
Best wishes for your Dad's RAM.
Hope this helped.
