Transmission problem
Cheezer88
Port Colborne, Ontario, Canada
I have a 2008 ram 1500 4x4. It will not shift into 4th or OD. When I put it in drive it starts out like in 2 or 3rd gear. When I restart the truck and put it in drive then it drives normal. After driving it a few miles it drops back down to 3rd and wont shift into OD. CEL is on. What is the problem? Any thoughts?
HemiLonestar
Navy Badge Coast Guard
MD
4th is an OD; the RFE has two OD gears. 3rd is the 1:1, 4th is .75:1 & 5th is .67:1. What you have is a failure of the OD clutches. I would be willing to bet money when you pull the codes (why haven't you already?) you will have p0700, p0734 & p0735. If so, your choices are replacement trans or rebuild yours.
HemiLonestar
MD
Ooohhhhh, you might be lucky then. Most people change the solenoid pack with this one and usually good to go afterwards.
