Transmission Shifting Late
MJA224
New Jersey
Lately I noticed my 2016 Ram 1500 5.7 L is shifting into the next gear late while accelerating. The RPM's stay around 2000-2200 for a few seconds then eventually drop and shift into that gear. It doesn't happen all the time time though. Any advice would be appreciated. Thanks
leowes
Drexel Hill, PA
Any codes stored in the pcm? Could be as simple as a fluid and filter change.
PoMansRam
East Aurora NY
6 or 8spd? How many miles on it? Any other issues?
I'd start with simple stuff like checking for ~14VDC across the battery with the truck idling.
MJA224
MJA224
New Jersey
8spd with 43000 miles. No other issues.
AndrewYu
Alberta, Canada
i had the same thing, but my truck is brand new. only one month old. dealer checked and said no issue find it. i have no idea what should I do now.
mtofell
Try resetting the tranny.... there should be instructions online somewhere. Basically, the trannys learn your driving behavior and adjust shift patterns, etc. It's possible it just got confused (for lack of a better term) and needs a reboot. Various things can make it start the "learning" over.
PoMansRam
East Aurora NY
Old thread here, but is this only happening on cold take off or all the time?
RLJ10X
Southern Indiana
Your truck up shifts at 2000 RPM, and that a problem?
I wish mine did that! A lot of times, mine shifts too soon, and them I'm chugging along at 1500, which SUCKS! I use th Slap Stick in my truck most of the time. Now, I have a he old 5/6 which has a greater RPM difference, but still, I like my RPMs at least 2000; 2500 is even better when I'm accelerating. Cruising RPM is 1700+.
I'd much rather spin an engine than lug it.
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
Give it another couple of months. It takes a few thousand miles for it to learn when new.
AndrewYu
Alberta, Canada
thank you for your reply. but every time I parked my truck for a longer period of time (over 12 hours) and when put into DRIVE mode, it will not go while accelerating ( feel like the truck stuck on the first gear and will not take off). The RPMs stay around 2000-2200 for 10 to 20 seconds then eventually drop and become normal. sent truck to the dealer, they told me there is nothing wrong. Thanks
Loudram
Navy Badge
South Jersey
Hemi 6.4L
That sounds like an issue not a learning curve. I'd try a different dealership or take it back to that one.
So they said they couldn't replicate it and since they couldn't there is nothing wrong? Typical dealer line. You might have to leave it there overnight so they can test it when it's cold.
AndrewYu
Alberta, Canada
yes, i did leave it overnight and let them tested drive, but they said, they did not feel it. and checked code with no issue.
