Transmission troubles with codes
Yamifz1
Greenwood, Nova Scotia
2010 Ram 4x4 Sport
Need some help fixing an issue, so here is the story....
I was leaving home, I was about 2 miles from home and come to a stop and feel my tranny push or downshift hard after stopping. I leave the lights and shortly after that the truck shifts into 3rd and revs really high. I stop and realize that a tranny hose let go and pumped out a lot of fluid.
I limp my truck home, clean out the engine bay cause it was a mess and then secure the clamps again. I then take it for a drive and now it throws codes.
1st -"P0933 Hydraulic pressure sensor range/performance"
2nd - :p0733 gear 3 incorrect ratio"
and finally "P0760 shift solenoid"
My thoughts are I need to replace the solenoid but not too sure so if anyone can help and provide guidance I would appreciate it before I throw all my Christmas money at the truck.
Thanks
Tach_tech
5.7L HEMI
Thanks
We’re those codes set after the hose blew off? Or are they current codes. If you clear them do they come back right away?
Yamifz1
Yamifz1
2010 Ram 4x4 Sport
They showed up after I refilled the tranny and went for a drive. If I clear them I believe that they all come back, or at least P0933 comes back for sure
Lemniscate_Mike
