2008 Dodge Ram 1500 4wd 5.7, 135,000 miles
Cruising at 70 mph with cruise control on. Truck suddenly shut down, I pulled over onto shoulder. Attempted to re-start truck, very difficult but did start. Truck ran poorly, not shifting into overdrive, cc not working. Pulled codes, showed crankshaft positon sensor issue. Replaced sensor, all was good for about 10 miles, then the exact same type of event. Pulled codes again, replaced cranckshaft senor again, all ok again for about 100 miles, then same event. Any help in what may be causing cranshaft position sensor to go bad would be appreciated.
