Regularjay
So I bought this 2013 4X4 Hemi Crewcab a month ago. I've noticed that sometimes the cluster lights and HVAC Control button lights flash on and off continuously when the truck is off . Not continuously on, they are lit for maybe 10 seconds, then go out for a few seconds then back on, the speedo & tach jump up to zero for a few seconds then everything off for a few seconds then the cycle re-starts - day or night. Doesn't do it every time I shut it off but more often than not (it's doing it now as a matter of fact). Searched on the internet yesterday and found others reporting similar things but they were all saying their batteries were dead in the morning, mine always starts (thankfully, so far). So, this morning when I started the truck (after lights flashing all night) I immediately scrolled through the EVIC to battery voltage (it was 14V) and see that my drive hours were zero and idle hours were at 58. I know that the idle & drive hour numbers were "reasonable" when last I scrolled through things.
Days after I bought this truck I swapped in an aftermarket radio from Crutchfield all the proper harnesses and everything no problems. I'm going to put the O.E. radio back in to see if it makes a difference in the flashing light thing. I'm thinking that maybe the power off delay (set at zero right now) is still long enough to somehow backfeed through the radio to confuse the truck about when it should power down and it's getting stuck in a self perpetuating loop of power off then on then off. Plus, the radio is the only thing not "stock" so if I remove it from the equation I'll learn something. But, I have no clue why the hours reset, no idea why drive went to zero while idle went to 58 (it may have been 58 before, I don't recall) I would have to guess that resetting drive hours to zero "should" take dealership level intervention.
I am very afraid that this truck is going to be an expensive pain in the wallet to own. I bought it from a private party so no warranty and I think I'm going to regret it. A lot!
