Truck Will Not Start and Gauges Will Not Move Until I Reset Computer
will2k520
Magnum 5.9
Help! My 2002 Dodge Ram 1500 5.9 liter V8's gauges will not move and my truck will not start until I reset my computer. While driving it can just suddenly die as if it has ran out of gas and then not restart until I reset the computer. I have changed out the crankshaft position sensor and the ignition switch and it continues to do the same thing. All fuses and relays are good and working. Truck has new K&N CAI, Big Gulp throttle body, throttle position sensor and idle air control valve. What should I check next? Thanks in advance for your help.
RonJon '06
Southern Minnesota
My guess is an electrical or PCM issue. I would inspect the wires and 3 plugs going into the PCM on the passenger's side firewall for dirt, looseness or cracks. Maybe check all your ground wires as well.
DahRamGuy
Mebane, NC, USA
bro im havig the same issue, did you find out the issue?
