tuning questions
greatwhite57
South West Pa
As you all know I got a diablosport trinity the other day. I'm runing the 91 performance tune and its running great. Now I got a couple questions. What is the wot fuel and spark settings do and what would be good settings for it. All that's done to the truck is a cai dual straight pipes and a throttle body spacer. I'm tryin to get the most power out of it to get my 37s rolling better till I get the gears installed.
truckin151
2013 sport
DO NOT.... I REPEAT.... DO NOT touch the WOT fuel and spark settings UNLESS ou have a wideband to monitor the AF ratio AND have done quite a few data logs, you will seriously f' up the motor that way.
A few things you can do is adjust the shift schedule, your 05' will do WOT, part throttle up/down shifts, adjust the throttle sensitivity, adjust the speed limiter, adjust the rev limiter, and thats about it until you get someone else to start making adjustments.
greatwhite57
greatwhite57
South West Pa
Oh ok I was just curious what they were about. I adjusted everything but the trans stuff right now. I'm still tryin to figure out my abs light situation
truckin151
2013 sport
Diablo has a fix for that on their site, have you updated it to the latest CROM release?
quietpeen
2021 TRX
Hellcat
really you could screw your truck up if you change wot fuel and spark settings? Are there any warnings in the software on the Diablo?
EJM05
Somers, CT
440 Big Block
Huh. Good to know truckin.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Ryan is correct dont touch that unless you have a wideband to see what your A/F is hitting at WOT. To lean and kiss a few pistons go by and the stock 5.7 rindland is already thin enough.
glass3222
Central PA
from you main page, press options and somewhere on there should show what crom you have. I cannot remember exactly where on under options though
glass3222
Central PA
if you need to update to the lastest crom, you will need to download the ds downloader software from diablo sports website. they have the directions and everything on there, and you can search on youtube for how to videos
truckin151
2013 sport
I know on the dsp it shows the crom version on start up.
