Turbo life expectancy
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
I have seen various threads of turbo failures at various mileages but mainly below 150K. What is the realistic turbo life expectancy in these 6.7 Cummins? Can they go 300K+ miles or is that a fantasy?
I understand failures for a given item are a running average but people are not going to post when things are going good, so all the anecdotal info is just on the failures.
Thanks for any input.
Reactions: SyN
WilliamS
Tampa FL
The problem is the answer is based on use. A stock truck unloaded will have a lot less stress and heat cycling on a turbo and its bearing and seals more than a truck that works it entire life loaded to capacity, or a tuned truck running more boost than the factory settings. The turbos are designed with an expected replacement of 250,000 miles but this can vary greatly based on load, location, and maintenance. Most turbo failures Ive seen are based on the bearing wearing out, it is spinning in 6 digit rpm range quite often so its a part that does a great job, but lubrication is its key to life. Oil not only keeps it happy, but also takes a part in cooling the center section, I know there is a water jacket as well, but both do the job of removing heat.
So the real question is, what will you be doing with your truck? Will it be a hopped up tuned up tweaked out racer, loaded up with a 15k trailer every day of its life, or just a grocery wagon?
Hootbro
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
Thanks for the input. I kinda figured it would boil down to duty cycle. Most towing will be a horse trailer every other weekend and the rest a daily driver.
I am a by the book scheduled maintenance kinda of guy and mainly run just stock and have no plans to run any deletes or tunes. I even actually follow the recommended idle cool down times before turn off. Nor am I racing or flogging it from point to point when I drive it. Basically drive it like "Grandpa" for the most part.
WilliamS
Tampa FL
Id see no reason it wont last into the 200k range then. Like you said originally there are off the wall cases of a premature failure and people lose their mind over it and its posted everywhere. I can assure you working for a Big 3 dealer, Ive seen very few Turbo replacements in my many years in the car business.
mtnrider
Georgia
Honestly of the few failures I have heard of, 95% of them were on tuned and deleted trucks. A well maintained stock truck the Turbo should easily last 300K.
WilliamS
Tampa FL
At least its not the 6.0 Powerstroke. Regardless of internet folklore it was a great motor, once tuned it was trash unless you fully built the top end "bullet proof" if not it was a hand grenade with the pin pulled
McBroom
Denison Tx
Hemi 6.4L
^^^ yeah at least it’s not a 6.0 powerJOKE ^^^
Blue Streak Pearl off-road
Administrator
It's not the flogging of the turbo (unless your tuned) that's hard on it, but not letting cool down before shutting down(especially if your running dino instead of synthetic). I've been told this by a couple of mechanic friends.
GunnerJ
US
Then I'm screwed in 10k, dangit
Damn...that means my truck is going to turbo hell in 50K miles then. :D
ehart814
Ecodiesel
08 6.7. Deleted, edge w/juice, 99% of run time towing (heavy). Turbo smoked at around 90k.
This is my dads truck and it was run hard by “disgruntled employees”.
90K under these conditions is pretty impressive. Not kidding about the 99% of the time towing. This truck switches between 2 different long goosenecks, the longer one is 40’. Yes it’s a dually. The 6 speed auto has been rebuilt and upgraded 3 times. It now has almost 113k
IMO, the old 94 with a 12 valve (still being used) is a way better truck. Odo stopped a couple years ago at 240K. 5 speed manual of course...
tucka71
California
6.7 diesel
K
Keep up on keeping egr clean....every 75k miles
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
Unfortunately my turbo just failed. Not deleted, fully stock only 25 K on the truck but warranty ran out 12 days ago. Not looking forward to it. dealership said they would try and cover about $2K of it. They told me they reset the P00AF code under a TSB and that might work, but I have my doubts. I might have to contact head office to see if they'll help. Which I doubt. After that I guess maybe a lawyer as I contact the dealership the day my warranty ran out for a check engine light but no codes, they told me not to worry about it, if anything came up they would help, now 12 days later blown turbo but little help.
