Turbo question
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
Ive been reading around and I see to run a supercharger a guy needs to run premium gas all the time, for the turbo'd gasser guys, do you need to run premium as well with a turbo or not?
1SilverBullet2
1SilverBullet2
North Dakota
Alright that's what I was figuring but none of the forums or threads said much about turbo's and octane rating, just super chargers.
MagSport
South Carolina
Check out some of the dakota forums, a lot of guys over there run turbos and have them set up pretty nice. But yeah like DD said premium fuel or a retarded tune is a must for boosted applications and sometimes the retarded tunes don't work either.
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
Turbos and blowers are basically the same thing...a compressor that, well, compresses air before cramming it into the manifold.
The difference is superchargers are mechanically driven via a drive belt (pay no mind to "electric" superchargers, they're bull****).
Turbos use flowing exhaust gas to spin the turbine.
The common and general consensus is turbos can produce more peak power while superchargers have quicker throttle response. Of course, depending on tuning and what you use, your only real dilemma is personal preference. And both will require higher octane fuel because the denser (and more fueled) fuel/air mixture will be much more volatile (due to higher cylinder pressure) and need such fuel to maintain stability in the compression stroke (preignition is never a good thing).
Me, personally, I prefer naturally aspirated, LOL. If I want more torque, I'd look towards a stroker, but that's just me.
