Turn signal issue
Douglas Walouke
Madeira, Ohio
2014 Ram Longhorn
So my dash computer is telling me that the right rear turn signal is out...but it’s not! The green arrow flashes fast inside, but it is flashing normal outside and the light seems nice and bright.
what could I be missing?
bhonshell37
Washington
2014 Ram Longhorn
Do you have puddle lights on your mirrors?
D
Douglas Walouke
Madeira, Ohio
Puddle lights? I have lights that shine down when unlocking with remote. I do not have the flashing light embedded in the mirror when activating turn signal.
bhonshell37
Washington
Have you tried switching the bulbs from each rear turn signal to the other side?
D
Douglas Walouke
Madeira, Ohio
I went to change the bulb, noticed it was working fine, so I did nothing. If ain’t broke...
Figured there would be a way to reset the dash computer.
bhonshell37
Washington
I am thinking that switching the bulbs to the opposite side will eliminate a bulb being the cause. Then you can move to the bulb housing
Tach_tech
5.7L HEMI
Is the cluster saying “ Right rear signal out” or is it showing a picture?
D
Douglas Walouke
Madeira, Ohio
Both. a pic of the truck with a highlight on back right tail light and the words Right Rear Signal Out
Tach_tech
5.7L HEMI
Does your truck have the LED tail lights? Is the front signal working correctly as is the signal light on the mirror?
D
Douglas Walouke
Madeira, Ohio
So another evolution in the problem. Yesterday, unexplainably, the flasher slowed to its regular cadence and the dash computer indication of the rear signal being out went away. Then, about 1/2 hour later along the highway, the dash computer indication popped up and the next time I flipped the lever to indicate a right turn, the cadence of the flasher picked back up.
Hmmmm….
All exterior lights all flashing ok despite the interior warnings. Someone suggested simply switching the bulbs from left to right.
sigsauerP938
