Turn Signal message
Turbojim23
Cummins 6.7 diesel
Both front and rear left turn signal lights are not working, I cannot see how to replace either bub if there is one. This is on a 2013 Ram 2500 crew cab long bed Larime with a 6.7 Cummins.
Is there a replaceable bulb?
I checked fuses , but could not find one specified for turn signal.
12sportmc
NC
If you have the factory quad headlights and incandescent tails it's pretty easy to replace.
Pull the headlight
1)remove grille
2)remove two screws holding headlight in
3) open flap in wheel wheel and push white tab up to release headlight
4). Pull headlight from truck
5) twist connector for turn signal bulb and remove from housing
6)replace bulb
Reinstall is reverse of removal. The white tab will be pulled down instead of pushed up on the inside of the fender well
Tail light:
1)open tailgate
2)remove 2 torx screws that secure the light
3)pull light from bed
4)twist the top connector and pull it from the housing
5) replace the bulb and reinstall in reverse order
Reticle918
