bereta1
How long does it usually take the screen to load from a dark screen ? Mine generally takes about 20 sec to load. I’ve also noticed when ign is turned to acc. The check engine light is on which is normal, and if I leave it on acc a bit longer the check engine light flashes about 10 times. The reason I’m asking is because I have a UO147 code present. I’ve been told it’s an issue with the radio. Any help would be appreciated.
