UAQ radio Navigation issue
DEON2212
SoCal
Hello, I’m having issues with my UAQ radio, I purchased it from lkq for a good deal, but the navigation dosent seem to work. It has good reception, xm radio, and compass work. When I try to enter an address it says “Map of current location is not available”. Updated to 40.1. https://imgur.com/a/ynfNsxP
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Looks good as far as GPS is concerned. I'm guessing it doesn't have any street data for the area of Mexico it thinks you are in. Personally, I would just use Android Auto or Carplay through the UAQ interface and leave it at that. Uconnect Maps are always out of date by years.
DEON2212
DEON2212
SoCal
I’m in San Diego, CA but it won’t even let me put in an address to navigate to.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Got it. Have you tried resetting the radio by chance? Also, you may be able to reflash the radio firmware to 40.1 again by going back to an earlier firmware first.
DEON2212
DEON2212
SoCal
I’ve reset it with JScan, unplugged it for a few days, plugged it back in. It was originally on 39.X (not sure exactly) and I flashed 40.1. Should a flash back? Also I was told some updates have navigation files. Let me know what is best! *wasn’t working on 39.X ethier
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
If it wasn't working on 39.6 I don't see a reason to flash back. 28.3 has a map update version but the maps are much older than yours.
I feel like I remember a setting in the Navy App for a reset too. I could be mistaken though as I never used the integrated NAV.
DEON2212
DEON2212
SoCal
I don’t mind using CarPlay, but if I ever resell it I want to make sure that it’s 100% working. Can I update to 28.3, Then to 39.6?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
You should be able to flash firmware freely between 28.3 and 40.1 with the UAQ. I have done it several times.
DEON2212
DEON2212
SoCal
Is there any specific way I should downgrade, One by one? Or can I just jump to 28.3.
DEON2212
DEON2212
SoCal
I also just saw that 30.24 has a map file, can I move the file to another software?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
What is your current version of maps? Most of the maps with the updates are way out of date and not worth it but newer maps are newer maps
DEON2212
DEON2212
SoCal
Content_NA_HM_20Q4
9.35.2.241210
Don't mind older maps, if it dose work I can always purchase an update in the future.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Content_NA_HM_20Q4
9.35.2.241210
I think your maps are newer already so I'd just remove the map folder and just "VP4_update" folder should be on the drive
DEON2212
DEON2212
SoCal
Just tried to downgrade with 28.3 and got an error, Vehicle not compatible.
Trying 39.6, if I dose not work I’ll try to add the older map updates. Can I take the map files from an older update and add it to 40.1?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I think @Mpgrimm2 and I tested this once and that worked for him but I could not get it to work for me.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Just did 39.6 No luck, by any chance do you know how he updated it? Do you put the map files in the VP4_update or leave them separate. @Mpgrimm2
Both folders would be in the root of the USB.
dakota18
