UConnect 5.1 and Samsung 8
zebraprs
It seems that UConnect software never catches up to the Verizon Samsung S8. Is there a work around where I can have my phone still sync up with the UConnect 5. 1 system.?
Everything works except for the Text Messaging.
Thinking of upgrading my 5.1 to 8.x. is this possible?
2014 Ram Base Model.
Rollinco
I have the RA2/Uconnect 5 radio and a Samsung 8+ which syncs fine and text messaging works. The radio I put in was out of a 2016 Ram so not sure if that makes a difference.
kad
Hudson Valley, NY
5.7L HEMI
I have the UConnect 5 in my 2014 and a Galaxy 5 phone on Verizon. When I first pair the phone, the text messages work then after a few on/off cycles of the truck it will stop and I have to unpair and repair the phone to get it back. I had to set the phone to "Display messages on lock screen" to get it to do even that. I don't think it's the phone or Verizon, as I have a Pebble smartwatch and it receives text messages from the phone without the messages on lock screen setting and without needing to re-pair.
-K
zebraprs
zebraprs
-K
My Galaxy 7 works fine as well. Just the 8 doesn't
Rollinco
I was on Verizon witha Moto Z Force when I put the RA2 in my Ram and it worked fine too. Currently on ATT with the S8+.
jabartram
Corpus Christi, Texas
2020 Power Wagon
Did you do all the updates for the phone, mine had to go through a few the day i got it.
zebraprs
zebraprs
Yes that is the problem... UConnect does not support the latest Verizon/Samsung versions ... I will check again...
My phone is on build# In the attached file. UConnect sw is usually a few builds behind...Screenshot_20171219-072429.jpg Screenshot_20171219-072429.jpg
jabartram
2020 Power Wagon
zebraprs
zebraprs
I just removed the phone (unpaired). Then added it again and the texting feature works... we'll see if it stays working.
zebraprs
zebraprs
Works for a little while then reverts back to not working
Guess it is time for a new radio...
kad
Hudson Valley, NY
5.7L HEMI
That's what mine does. But unless you're talking about going aftermarket, I don't think replacing the radio will help.
-K
zrfraser
3.6 Pentastar
my Iphone 6S does the same thing. It will work for a couple of days and then stop. It used to bother me but my wife likes texting more than talking so when I'm going to work I don't see the text pop up every 30 seconds. I just keep my phone on a mount next to the radio now so if one comes in I can glance and see it,
61N150W
Anchorage, AK
I've mentioned this in another related thread and worth a try; I find not allowing my phone to pair to other devices will keep it in sync with my Uconnect.
I use Bluetooth headphones at work pretty often. When I reset the Bluetooth connection to my radio, it will work just fine all weekend till I turn on my paired headphones come Monday morning. You can "forget" all other saved pairings and give that a go. Although there doesn't seem to be a cure-all, this works for some.
While this method seems to be stable for me, I prefer leaving my other connections and getting a break from my phone. Even when it does operate as intended, I find it distracting imo. [emoji41]
BIGRed333
Houston, TX
Cummins Turbo Diesel 6.7
I'm not positive, but I believe it won't read group text messages or texts with jpeg/gifs. Basically MMS is out. It will read SMS. Thoughts?
