Uneven muffler tips after carven install?
Throwin Plugs
New York
Question guys. Anyone who installed a carven muffler on their ram, did your passenger side muffler tip stick out more than the driver side? I figure I could always trim the pipe the 1/2 or so just curious. And yes I did remove the indexing pin.
Bandit517
That Trials Guy
Wauseon, OH
I forget which one was shorter on mine but I ended up loosening the shorter sides clamp and sliding it back a little. It's still not perfect but definitely better than it was. I'm going to get some 5" tips before I bother making final adjustments.
Treburkulosis
Glorified Car Washer
Haslet, TX
Thats a good 1-2 inches. Dang. I hated the Challenger and the way I believe its the left tail pipe sat down on one side.
atc06jh
Middle Georgia
I did mine and had the same issue. Spent an extra 30-45 minutes adjusting the tips to get them right. They may not be exactly perfect as if stock, but nobody notices at all it’s so minor. Maybe 1/8 of an inch off from each other so I’m good with it.
