UOA Blackstone
Bubba13
Hamilton Ohio
Here is 3 oil change reports from blackstone labs. I use PuP 0w20 with fram xg 10575 filter. The last oil change had 1700 plus miles on it. This oil change was the freebie from the dealer. I gave them to use my 10575 filter to put on.
Does anyone have any idea why the copper jumped up? I do not hot rod my truck!
Jeff
  • 22_RAM_1500-240429_(3).pdf
Sherman Bird
Houston, Texas
copper.... main or rod bearing worn excessively. I'd suspect the main thrust. You can check crankshaft end play pretty easily at the front pulley.
clay282
Anon
3.6 Pentastar
aimcgma
