UPDATE: Fox Suspension on the way
rgrbobbyedwards
rgrbobbyedwards
SC
2020 Power Wagon
Per instructions for the extended rear sway links, it mentions the stock ones are on the inside and theirs go on the outside. Am I looking it wrong cause the stock ones are on the outside
G. Mcpherson
Yacolt, Wa.
2023 Ram 2500 CC SB Tradesman
I do not have any Pic's. Everything fit.
BolletuH
Wyoming
Follow his instructions everything will fit and have proper clearance. Also, for the rear springs make sure they are mounted with the bottom isolater tab facing towards the rear of the truck and that both springs are pointed in the same direction aka in-phase with one another. I made the mistake of installing them out of phase and had to go back and fix that.
Coll4646
Elgin, IL
Good luck with the install today! My Thuren front/back shocks and coils come today and I’ll be installing tomorrow, would certainly appreciate any advice!
Hope they all go in easy!
rgrbobbyedwards
rgrbobbyedwards
SC
2020 Power Wagon
Will be posting a write up later tonight. Finishing up the rear time now
rgrbobbyedwards
rgrbobbyedwards
SC
2020 Power Wagon
Good stuff. Thanks.
rgrbobbyedwards
rgrbobbyedwards
SC
2020 Power Wagon
What’s the difference between the shock mounting nuts (stem top) and the shock tower nuts? Trying to figure out what needs two full turns vs 55lbs torque
Dinky
Oregon
Eye bolt is the lower front and rear. Stem top is front upper and shock tower nut is upper rear.
olyelr
Kewadin MI
Seems odd they call the top mount for the shocks different names and install differently, when they look to be identical ?
rgrbobbyedwards
rgrbobbyedwards
SC
2020 Power Wagon
Good stuff thanks. Should I back off the 55lbs on top of the shocks and go to snug + 2 full rotations? 55lbs felt just past (pretty close) 2 full rotations but I don’t want them over tightened or is there no concern?
rgrbobbyedwards
rgrbobbyedwards
SC
2020 Power Wagon
Also, this is the last thing I can’t seem to figure out. I know it’s simple but I just can’t “see it” or picture it. Can someone break this down for me or post some pictures?
Dinky
Oregon
They are generic specs. The older 2500s didn't have pin top rear shocks. The bottom bolt goes through eye holes and the top rear mounted to the frame on a stud like my 3500. The front is a pin top and typically has a spacer so you can't over tighten with a nylon nut.
Dinky
Oregon
You rear shocks are pin tops I would follow the torque specs for the front to the rear. There should be a spacer in the rubber bushing to prevent over tightening
rgrbobbyedwards
rgrbobbyedwards
SC
2020 Power Wagon
They are generic specs. The older 2500s didn't have pin top fron shocks. The bottom bolt goes through eye holes and the top rear mounted to the frame on a stud like my 3500. The front is a pin top and typically has a spacer so you can't over tighten with a nylon nut.
Appreciate you
wobly
Colorado Springs, CO
2021 Ram 2500 Power Wagon
From the Thuren page, you might not need the bracket.
"The 2019-2022 trucks uses a rubber guide that functions fine with our added travel. The use of this bracket allows the cables to be less restricted, so we can add more suspension travel without kinking the E-Brake cable housing."
rgrbobbyedwards
rgrbobbyedwards
SC
2020 Power Wagon
You’re the man
Alignment is done. Headed to pick up and bolt on the king damper and we are mission complete
