Upgrade everything??
Mopower318
Garden City, Ks
Magnum 5.2
Just joined the forum because I have a few questions. First off I have a 1996 ram 1500 with the 318 and a manual tranny. I wanna make it an all purpose vehicle( dd, wknd wheeler). I wondered if anybody knows of a great lift kit( in terms of articulation not looks). Regearing I know I'm gonna have to do just not sure what gears to go with (3.55 currently). I would like to get more power out of my 318 or maybe convert it to be carbed so I can run whatever cam I want to. And lockers I was thinking something cheap for the rear and maybe a cable actuated locker for the front.
BennyLumpkin
Central PA
5.9 Cummins
With a bit of tuning(custom programmer) you can run most any cam you want now. With fuel injection you can run at any angle you want and won't flood out like a carb will.
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Welcome to RF!
Building a functional, reliable vehicle and going cheap can't be found in the same paragraph...sorry. Been there, done that...when I was 21.
Gds...has that really been 35 years ago...!
I degress. But..if you want a goood HD lift lit, then checkout Dodge Off Road. Dj makes some killer stuff. Then you'll probably want something cheaper and have to settle for Top Gun or similar. Kits like Rough Country or stepping up to BDS are fine for weekend warriors.
Gears are a bit dependent on tires, but 4:56 and 4:88s are about as low as you can go on them. The problem is is that if you are serious about off roading, your stock axles won't live very long with anything over a 35 inch tire.
Your 318 can be built up pretty well without going carburated...fuel injection is soooo much more reliable off road anyway. There's not much in the way of tuners for a '96 with the old OBD1 technology, but you can still build a pretty solid engine. You'll want plenty of bottom end torque for pulling, not top end horsepower.
I would say when you've done a bit more research on your own and have a more definitive plan, we forum members can provide a bit more information.
That would include how big of tire, lift, etc. It's a bit too easy to speculate, but 5 inch lift, 4:56 gears, rear powertrax differential and a fresh longblock with some mild mods would make a reliable dd/ weekender, especially a manual tranny with a granny 1st gear.
MADDOG
Living in a Firepit
6.4L HEMI
One good source of tuning for a stock SB, built SB or stroked Magnum 360 (to 408 cu.in.) is B&G Performance.
M
Mopower318
Garden City, Ks
Magnum 5.2
Thanks for the help so far guys! I know I dont wanna go too tall on the lift and raise my center of gravity a lot. I was wanting enough room for 34 maybe 35s to be able to articulate. With that size of tire I want the gears to still be able to run 70 on the highway. What do I need to do to address the main problems with the 318 and improve performance and efficiency?:killer:
