urgent. Crew cab seat in quad cab
kg93
AZ
Has anyone on here done it?
I was actually about to buy the full interior of the rebel from seats an such. I called him and he said that the crew cab seat will fit the quad cab. Its the 70/30 seat i have the full bench seat.
He said that the bolt holes are hidden under the carpet and that a hole just needs to be drilled into the new brackets.
Can anyone confirm?
charonblk07
Calgary, Ab
F1-A forged 349ci
The seats are the same between the two cabs, there's just more leg room between them. I can't say about the 60/40 vs solid bench issue though as all my trucks have been the 60/40 split.
kg93
kg93
AZ
awesome thanks, screw my friends leg room hahaha. I would assume if quad cabs have the 60/40 option that they have the bolts under there. I doubt they would make different cabs
kg93
kg93
AZ
Why not?! It's only money.... ;) :waytogo:
Adam
Hahahah good chunk of money. I figured I was going to eventually get leather so that would be 600+ plus the install. And the center console would be 500-600 and shipping. So now I have power seats and heated if I can figure out out to get that to work
Sent from my LG-H900 using Tapatalk
hunter99
I am pretty sure the holes are there and already threaded. They literally just put a sticker over them. Could be wrong but I would be surprised. I get a different harness but usually body and frame times are all the same. Too much of an expense to have different versions of those.
tsc
Let us know how it works out. I wanted to put a 60/40 split in my crew. But I only found one from a quad.
I called my father in law and he measured his quad bench (seat back to front) and it was shorter then my measurements on my crew. So I opted not to switch out. The bolt hole locations were exactly the same distance. But the bench depth; if I remember correctly was 2" shorter in the quad bench
danmp
Québec city, Canada
I was planning to do this, but I mesured the seat in a crew cab friends truck, and the answer is no. The bolt pattern for the seat are not the same. The distance between the bolt was around 19" in a quad cab and the crew was near 21.
kg93
kg93
AZ
Ghstrdr95
