Used parking brake maybe 8 times now it’s saggin?
Addicted2fishing
Addicted2fishing
Durham region
HEMI 5.7
Ok so my brake cable is still sagging and I have been putting it off (prob shouldn’t). I’ve read a couple threads and google and some people mentioned removing the axle to fix the issue ? WTF? Removing at Axle to fix a stuck brake cable ? Little pissed right now.... truck 3 years old
60% of the time it works every time....
BadHemi2014
Greater Cincinnati area
Technically you are supposed to remove the axle to get to the parking brake setup to replace the shoes and hardware. However it can be done without doing that, at least I've seen it done on YouTube lol.
My brakes are a rusted mess so I had this same problem with the cable.
Follow it back to the wheel, it attaches to a small lever. This lever is probably stuck forward. I sprayed the heck out of everything with blaster and used a little persuasion (screwdriver and mallet) to tap it rearward, thus straightening out the cable. I'll try to get a pic later.
Of course this might not be a permanent solution if your parking brakes are a mess but it will at least get the cable back where it belongs!
BadHemi2014
Here's a couple pics.
With parking brake on, lever is forward (not a lot of travel)
With parking brake released, lever should move back toward rear of truck
These are pics of drivers side, passenger side is same but flipped upside down so lever is on top. Because ya know, they had to make it more confusing.
Basically, if you can get those levers freed up that should take the slack out of the cable.
Addicted2fishing
Addicted2fishing
Durham region
HEMI 5.7
Thanks! I pulled it towards the back and the cable tightened up. Sprayed some deep creep but still sticks [emoji2369]. Maybe a better lube ? Not sure I’ve seen PB in Canada. I know I live in a salty winter area but come on!
I wonder if they would cover this under extended warranty
