MartyZ
- Feb 10, 2020
- 834
- 551
- Location
- Lake Orion, MI
- 2014
- 2500 5.7l Hemi
My main reason for venturing down this issue is my truck struggles with gear hunting a lot.
(2014 2500 5.7l)
So I have been reading around the forum and doing some research into the best way to compensate for my 37" Tires.
The Truck in its current state:
The axles have not been re-geared. (3:73)
Tire size is off in system (Gives a slower speed on the dash than real time. MPG is off)
Basically Bone Stock with a lift and larger tires.
One of my options is Alpha OBD;
This will correct the tire size in the system (and allow me to use my new mirror lights, separate project)
What I'm unsure of is how effective Alpha OBD will be at correcting my gear hunting.
Another option is re-gearing my axles to 4:10 to get my power back to the road.
I was really leaning this way (and still am a bit) but the cost is way over my budget right now and I'm not sure I would be able to do it myself in a timely manner.
The other concern is that I heard re-gearing wont fix all issues and you may still gear hunt, have speedometer off, etc.
So in the mean time I stumbled over a few threads where people had mentioned using Tow / Haul all the time and said they saw no negative effects and actually saw their gas mileage go up in some cases and a lot of restored power to the road.
I hadn't really used it too much because I wasn't sure if this would cause adverse wear & tear to my drive train. (Larger tires)
I decided to see its effects for a few weeks using it all the time:
The first thing I noticed was the RPMs were slightly higher (Normal) and engine braking was much more noticeable. (Also normal)
But what shocked me was that it didn't eliminate O/D (at least what I could tell) and when I was cruising at 55 (50 on the dash) it was not gear hunting or feeling sluggish. The RPMs were even lower than without Tow/Haul, it was riding below 2000.
The truck seems more responsive and comfortable in its gears.
Current MPG before using Tow / Haul: 8.9 (again, not accurate due to tire size, but well use it for reference)
I'm curious if anyone else has done this or knows something I'm missing, In the mean time I'm going to continue using it and giving some updates on here.
PS: If I'm going to break my truck, please slap me, Its my daily and cant afford to wear **** out quicker than FCA designs it to.
(2014 2500 5.7l)
