Vacuum Line 2014 5.7L
shdtree3
Hello, while removing the intake from my 2014 5.7L i found this line and am not sure what to goes to it is not capped off and is open, I do not see anywhere for it to go to and it is held in place with factory clips.
Dave Schell
I love finding these answers on this forum, Changing plugs I ran into the same question regarding the same line. Thank you for the answer
TGrooms
North Carolina
Hi, I'm about to remove the intake head, I'm new at this, Is it hard to do? I have what i think is a fuel line that goes over the intake how do i remove it?
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
You don't remove it as it's part of the fuel rail setup. Remove the intake with the injectors / rails in place, unless you are removing the injectors for some reason. The fuel supply line connects to the fuel rail on the drivers side. Disconnect that from the fuel rail, ONLY after relieving the fuel pressure on the fuel rail at the schreider valve.
PS: Intake "MANIFOLD" and "HEADS" are two vastly different components.
Suggest you start your own threads for questions and keep to one post per subject to be able to follow responses. Especially, as you stated, not really knowing what you are doing. That thread you started re: the milky oil / overheat started this conversation and I would stick to that original.
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
Daw14
South Florida
search for a diagram or a book about the hemi engine.
It sounds like you are going in blind, and without much if any experience.
Is it the intake manifold or cylinder heads that you are trying to remove ?
What are you trying to accomplish ?
TGrooms
North Carolina
My radiator busted, it ran hot, i shut it off as fast as i could but ive got a brown sludge in my coolant now. I was told it was the engine oil coolant under the intake manifold but found out by the Dodge dealership that my truck don't have one.I checked the dip stick several times an it looks fine. Yes I'm new to this because i don't have the money for a mechanics repair cost so I'm trying learn as i go
test port on the fuel rail is a schreider valve. I have used an old refrigerant gauge set to see pressure / relieve it off the fuel rail.
No schrader valve on a hemi's fuel rail
As stated stick with your other post. You just make it confusing by having 2 threads going on the same issue.
mlgower
Little Rock, Arkansas
4.7L
Transmission breather line. It does not connect to anything. It is in the appropriate location
Oh Thank God!! It had me freaking out that something was missing. I am replacing the camshaft and lifters due to failure and found this while taking it apart. This is a "new to me" truck and there is already issues with it (which I hope to resolve). Thank you so much for the info!!!
mlgower
4.7L
Dang, I had the same question on mine. Thank you for asking so I didn't scour the internet for the next several hours trying to figure out what was missing on this truck. You're the Hero we needed!
