vacuum:O
gorman8523
Hi thischas probly been discussed a hundred time but I'm new a in need of help when I got my truck 99 1500 2wd 3.9 the air only blows out the defrost . I know it a vacuum problem and I found the problem on my second check valve there is only one line goin in the firewall it missing the vacuum that goes through with the coil lines . My question is were does it go I don't know where the other end I suppose to be . Thank you for your help
