Variable rate coil spring upgrade.
JaysFan9292
Saskatchewan
Hi everyone first time Post. I read alot about the air bags inside your coil springs, but has anyone tried upgraded springs instead. If so how has this worked for you? Thanks.
billyw
Northwest
The TTC-1223v variable rate springs will leave your truck a little lower than stock, so you may want to consider adding a small spacer too. They ride great. I found that they didn't provide enough oomph, and went with a stiffer spring. Air bags are a viable alternative too. Lots of choices and choice is good!
JaysFan9292
JaysFan9292
Saskatchewan
I assume your happy with your stiffer springs. Not too rough of a ride unloaded? The airbag route can be cheaper, but I like the idea of the springs being able to handle the load themselves. And no air leaks to worry about.
jawzs2
Air Force
South Jersey
I second the 1223v's, depending on how often and how much weight you plan on loading. I've had them on my truck for several years now. They only dropped the rear about 1/4-1/2 inch at most, ride almost exactly the same as stock. I only tow a roughly 7,000 lb TT 6-8 times a year, so for me, they work great
JaysFan9292
JaysFan9292
Saskatchewan
My trailer is about 7500, so I'm pushing my limit. Thanks for the input.
billyw
Northwest
The springs I chose would be equivalent to the regular 1223 springs. They are stiffer, and when I experimented with LT tires, it was too stiff. But when I went back to P metric, the ride is good, and has actually improved over the last year. The springs have become more forgiving. The 1223 springs will raise the rear of the truck quite a bit unloaded. If I did it again, I'd opt for the 1211. Air bags could be a good way to go too. I don't have experience with them, but many here swear by them.
Cardhu
MB CAN
I did 1211. put rear up .25 to 3/8 inch. was firmer, tows a 5400 lbs camper great. I did not go 1223 V as i have ram boxs and carry ****. I did not one lower than stock and having the first easy soft coils negated with the weight i carry in the ram box.
you may wish to consider new front shocks like the bilsteins as they will seem soft given how firm the rear is. I'm waiting for the right time to change mine and would probably go with the 1.6 setting to keep rake and level when towing.
crcraft
