Vent leaking water
Mark A Palmer
Louisville, KY
2016 Crew Cab Work Truck
I need to replace the two vents in the rear cabin wall. I see a bunch of YouTube comments on this, but I want to make sure I order the correct part number.
Can someone advise?
Thanks.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Can someone advise?
Thanks.
Part Number 68323649AB
Good thread here on the revised part...
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Did mine in about 90 minutes. Hardest part was pulling out the seats. The new OEM vents are about $25 for the pair
TIP: Tie a string to the old ones before removing so they don't vanish between cab and bed. Same for the new ones during install. Just need to "force a little bit" through the hole and at an angle (they flex pretty easy if warm)
PS: 73 here and was not a problem at all for an old timer.
