(VIDEO) Front Bumper Spacing Issue
Vancouver604
Hemi 5.7L V8
So since I just posted this in a post I don't think many of you saw it.
My front bumper sits weird and my right headlight does not have the same spacing as the left.
When I took it to the dealership they said I was being to pick and wouldn't even try to fix the problem.
Here's a video of the problem:
Dodge Ram 1500 Front Bumper Spacing Issue - YouTube
Am I wrong?
Texasez
Dallas tx
The dealer here adjusted my whole cab on the frame because the steel part of my bumper didn't line up well with he plastic cap and left a space.
BlkRamRt
SoCal
HEMI 5.7
Did you buy your truck new or used?
JCJ4290
2014 CC 4X4
Keep in mind it is basically plastic. Sometimes vehicles get damaged during transit and the dealer secretly fixes them. But, it is under warranty! So yayyy! Mine was like that until I installed my headlights and suddenly the problem was gone! You also need to keep in mind that typically the passenger headlight is aimed differently than the drivers, so there will always be a slight variation
BlkRamRt
SoCal
HEMI 5.7
that sucks but its fixable.
Peti817
DFW,TX
4.7L
I have the same issue, I have a chrome front bumper and the plastic bumper piece that overlaps it between the headlight/front grille and the chrome bumper. Have yet to go to the dealership about this issue as I've been so busy with work.:mario:
HLram
2012 and 2007
Hemi 5.7 in both
mine was similar after I bought it new. Didn't notice it for a while. All I did was loosen the two bolts that hold the light assembly in place and wiggled the whole thing and shoved the light to the side and re tightened the bolts. Then adjusted the lights to match each other via the adjustment screw in top of fender under the hood. The gap was off next to my grill also. Aaaaannnndddd, lol, the fender didn't match the hood right above the light on other side so I mashed / pressed down on it a few times lightly and now it matches the contour of the hood. They are still not Mercedes perfect by any means but it is much much better than before. Easy, free fix
Vancouver604
Vancouver604
Hemi 5.7L V8
I do have plans of getting new headlights here in the truck within the next couple months so I think I will wait till then to pursue fixing the issue. Still ****** me off reading that all you guys are saying its a simple fix when the guy said it needed a whole re front aligning. This truck as long as I have it will be continued to be modded out so who knows maybe an ADD front and back bumpers down the road!
HLram
2012 and 2007
Hemi 5.7 in both
Oh yours may actually need a re-align ya never know. I just know that mine was very very very similar to what urs looks like and I was able to adjust them. I hope urs works out.
Trupiano
Registered User
6.7L CTD
I know my on my friends 2010 2500, he had to space out his front bumper with so he could run bigger tires and not rub. I also remember when I removed my front bumper on my 05 ram, there was elongated holes where you could adjust how the bumper sat.
Reason I'm saying this is it's most likely an easy fix, that you could do with a friend in an hour or two by just loosening the bumper bolts and setting the angle you'd like. Granted it would be nice if the dealership fixed their mistake for you, but seems like customer service is hard to come by these days.
HLram
2012 and 2007
Hemi 5.7 in both
I think his grill to bumper gap is ok it looks like his light is crooked?
KozzyJr
Ontario, Canada
i have the same ******* issue. my drivers side door was rubbing on the inner fender and cutting through the clear coat. once the dealer solved the door issue i noticed the head light problem. horrible.
Vancouver604
Vancouver604
Hemi 5.7L V8
The guy at the dealership literally told me what do you expect you bought a dodge and that was their fit and finish quality.
I'm so mad at that dealership let me tell you.
Here's a pic:
JCJ4290
2014 CC 4X4
I still think that's how it's gonna look as long as the headlights are aligned right. But I completely understand your frustration. But, it's a beautiful truck so don't let something so simple bother you.
Peti817
DFW,TX
4.7L
I work on 2012+ vehicles. I had a 2013 Ram 1500 Quad Cab up on the lift and figure I peak up underneath too see how my front bumper is mounted up on the truck. The frame of the truck is what my bumper or rather our bumpers are bolted up to. I'll take a picture tomorrow if I can get one up on the lift again. I am kinda nervous seeing as the frame is bolted to the bumper :banghead:
Vancouver604
Vancouver604
Hemi 5.7L V8
thanks!
Looking at it I get a impression that it is something to do with the lights but It could be just everything that needs to be realigned aswell
alphaprojects
