Visual code on instrument cluster
Knoxville_3500
Knoxville TN
Hemi 6.4L
This symbol popped up on my instrument cluster on the way in to work this morning , anyone know what it is. Truck is a 2018 3500 w/5k miles 6.4L.
Quyonmob
Canada
Gas cap. Had the same icon, and the same “wtf is this pic” moment.
mine actually turned out to be part of the sending unit and it was all replaced under warranty
start with re-seating the cap
K
Knoxville_3500
Knoxville TN
Hemi 6.4L
Hey Quyonmob , Thanks for the information. Did your truck have any other symptoms before this issue with the sending unit happened?
The reason I asked is because my truck does idle a little rough at start in the morning and I was just wondering if this is normal for this engine or not (6.4L).
Quyonmob
Canada
I have half the motor you do (3.6) but it did run rough, and stank like raw fuel. Only had 3000mi on it.
sending unit was cracked, causing fuel delivery issues, hence the problem.
Raadz
