Volant CAI install
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
I'm putting in a Volant cold air intake, number 16759 in my 2005 5.9. It's supposed to be very close to a drop in, but it's not, at least not on my truck and I'll show pictures of what I had to do to make it fit.
Interestingly enough, the same problem I have with the Volant kept me from installing a stock airbox I got off Craigslist.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Nope. Not a thing as far as I'm concerned, but my truck didn't come with one, and the one I got off craigslist wouldn't fit. It looked correct but it just would not seat. This is a compromise.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
So this is what I was replacing. Sounds like the runway at a major airport and sucks in all of that hot under hood air.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Part of the problem I had with getting the stock air box to seat was the inner fender shield was just in the way. I had the same issue with the Volant and had to do some surgery. I don't have a before picture, but this is what I had to get rid of.
This is why
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
This is what I end up with. If you try this, be very careful of your AC lines. You can see where one of the previous owners gouged through the paint getting the original airbox out.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
So the airbox and filter mount is a two piece affair and fit is.... questionable. This shows the gaps on both sides that point into the engine bay.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Not dealing with that. So I made a gasket out of some ballistic foam packing material.
Sealed up tight.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
So up in one of the pictures above you will see the speed nuts that replace the rubber grommets that the stock airbox uses. The bolts they include look to be nice stainless bolts. The only problem is they are at least 1/2 inch too short. Had to get some replacements out of the garage.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Once I got the bolts in the airbox, everything else was fairly simple. I had to drill the tube for the airflow sensor screws. The kit comes with two rubber washers. Those are spacers. You want to set the sensor in the hole, start the screws with the rubber spacers between sensor body and the tube and then slowly tighten the screws in an alternating fashion until you just snug the rubber spacer. You DO NOT want to push the sensor all the way into the tube or the o-ring acts like a lock. Sorry, no picture.
The air filter just squeezes into the box. If you guys have taken the glove box door off, it's like that.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
And then it's just tightening all of the clamps. Getting the sleeve that mates the intake tube to the airbox is best done with the bolts that hold the airbox in place loose. With the air filter off and the sleeve on the tube, you can reach through the air filter mount to help get the sleeve over the airbox side.
This is what it looks like all done.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
I ran it for just a minute to see what it sounded like. No comparison to what was there. I like the wine of a turbo as much as the next guy, but on my truck that other intake was like a megaphone. It was deafening. The Volant is MUCH quieter. I would say very close to stock, but I have not heard a stock 05 so I can't really say. I like the sound, that's what I was going for. That and an intake that draws fresh air.
I'm pretty happy with the end product, but I had to "add 3" to make it a 10.
The box includes a round "take off" on the bottom so you can add a snorkel. May try that in the future just to say I did.
Fuel35 67
Hanford
I like it when people take something not designed to be there and make it fit/function! Good job!
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Well, this was supposed to be designed to be there, just some of the execution was sloppy. But if it dropped right in it would not have been any fun to do so I'm good with it :)
Fuel35 67
Hanford
You sss as I’d it wasn’t a drop in for your truck, that’s why I said that I liked the “execution” of it. Good job all around.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Sorry for the confusion. It was supposed to be a drop in, but it turned out not to be. That's what I meant.
I'll edit that post so it's more clear.
06 Dodge
6.7L CTD
Now that you tell us why I understand why you installed it, sad part is the factory box air flow is good for 500 HP so I never did understand why so many bought into the idea they needed more air....
