VP3 NA
Klink
Reno
I bought VP3 NA used, the touch screen is off. Example, to X out of something I need to press way up in corner. Not sure if there is an easy fix. To top it off, since I don’t have audio controls on the steering wheel, I can’t seem to change volume. Anyone have any ideas or advice? 2B9117C0-9515-4512-9E58-6C86219EA607.jpeg plus does anyone know what the purple plug is for. Thank you and pm me if you want about this.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I bought VP3 NA used, the touch screen is off. Example, to X out of something I need to press way up in corner. Not sure if there is an easy fix. To top it off, since I don’t have audio controls on the steering wheel, I can’t seem to change volume. Anyone have any ideas or advice? View attachment 235830 plus does anyone know what the purple plug is for. Thank you and pm me if you want about this.
Purple plug is cellular antenna...
Klink
Klink
Reno
Gotcha, do you know if there is volume control built in the radio that i can’t seem to find?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I'm guessing you came from a lower tier factory radio. You need to add steering wheel controls or do the full 8.4 upgrade if you want to control volume. I do not recommended anything from Infotainment to do this upgrade...
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Did you change just the radio? Not the bezel too? The 8.4 dash bezel has the radio controls on it
Klink
Klink
Reno
I only changed the radio, I will look at the bezel. Thank you, as far infotainment, way over priced. lol.
rixter99
SW Arkansas
2014 3500 SRW
Cummins i6.7
Go to the AlfaOBD section in the forum and read the RA2 to RA3/RA4 Conversion thread listed on the first page...It lists parts required (Harness from m2 mods, bezel, other parts)...I just did this mod and I'm waiting on the harness pkg...
