Wanna lift front 1" only....best way?
Lee888
Sevierville
Hello, I own all stock 2018 Laramie 4x4 crew cab w/20" wheels, I like to raise front just 1"...max 1.5" for the look I want. I know most folks go more, and I've researched 2-3" using Billsteins & spacers pros/cons. Anyone sell 1" spacers? What are my best options?
Thanks for looking and appreciate any opinions/advice.
scott68fl
3.6L V6 Pentastar
From reading other posts I would think your best option is the Bilsteins set on one of the lower points.
Sent from my LG-H932 using Tapatalk
scott68fl
3.6L V6 Pentastar
Also using Bilsteins just haven't been able to gather enough time to install them. Found a local 4x4 shop that says they will install the fronts for $200.00 going to let them do it for that price. I will set mine at the 2.1 setting.
Triumphx
Just a friendly reminder-install the provided washer under the upper shock mount and then the nut above the upper shock mount. You don’t want to install it twice!
Gary2
S Jersey
I went back to 1.4 for a better ride from 2.1 and a number of other settings trying to get the ride and look I wanted . I also have a 3" Body lift so it still looks ok. It never really settled on any setting I tried using OE springs that had probably settled long ago. Now when I tried rancho quick lifts they settled a little but they came with new springs so it was to be expected.
