Want to add lift after bilstein kit
PDTRAD73
NJ
Penstar 3.6 V6
Getting bilsteins installed all the way around. What lift should I go with that I can still use the bils with, that’s economical to get away from the stuffed look? Purchased nitto ridge grapplers 35s
BOWERSFJ
Uniontown OH
Zone 4"F/3"R with Bils set at 1.4 on 35 x 12.50's .... Still fits in my 7' garage door, and most parking garagescb1cd99e611550bd2d850f4307560e4f.jpg
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
I had Bilsteins 5100s and just swapped them to beefier 6112s. I run a 6" Zone lift and run 37 Nitto Ridge Grapplers.
JB1
Houston, Texas
The rear Bilsteins will be too short to work with a suspension lift. Your front Bilsteins can be used with just about all the suspension lifts but depending on lift height may need adjusting up or down
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Yeah, you "can" use the rear Bilsteins... but you won't like the results. :( (speak from experience).
Nick@GotExhaust
Supporting Vendor
SC
These guys pretty much got it covered. you will need different rear shocks. if you would like a quote on a lift kit and shocks send me a message.
