Wanted to show my blue led conversion
zuiquan1
JB Charleston, SC
I will be tackling this mod in a couple weeks, got the leds for it, waiting on some replacements parts for my soldering gun to come in.. I see you successfully changed the evic screen, what did you do for that? I have the dual zone climate controls and want to change the digital display to white to mach the colors Ill be switching to, didnt think changing the digital display was feasibly possibly but seeing your evic make me optimistic.
V
Verdict1
Jacksonville, NC
For my evic screen I used 6 PLCC-2 90°. Only place I found them was here CrazyLed's. Dont know if its the same used in the dual zone climate controls.
ltr450rider13
Can you still use the reastat dimmer? I don't think led's are dimmable right?
harr118
where do you get these lights? for your gauges
rblochli
NJ
2024 Limited
Hemi 5.7 eTorque
SWEET! Great job!
QuinnII
2012 1500 QC 4X4 Laramie
oh man I want that so bad!!!! even with a DIY thread, I probably couldn't do that. sounds very complicated
I second hat motion, and I would be too scared to mess something up
RevRonnie
How do you do that? i want to do it on mine!
srqFF
Sarasota FL
Do you know the type of bulb that is used as the ambient mood light on the roof console? It's green and I wanna change it to red.
V
Verdict1
Jacksonville, NC
On that one it was easier just to remove the stock led and install a 3mm led. I just put alittle plastic epoxy on it to hold in place. Wired with resistor to factory wires. Also it was pretty bright with the blue I used, so I played around with the resistor to lower the output. Sorry but I dont remember the final value.
SELARAM12
Downey, CA
HEMI 5.7
which led lights did you you for the center console and the ones for the doors
craigsez
Novascotia,Canada
As bad as i wanna do that to mine(red though in my mango tango)it just seems to much detailed work and i really dont have the patients for tedious ****..
Power247
High Point, NC
6.4 HEMI
Insane work!!! Welcome.
Sent from my Nexus 7 using Tapatalk 2
Steve Holtz
